- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I use a SGDMA to stream a Frambuffer from SRAM to Display via LVDS
when e put a second LVDS Display to the same pins, i got a SRAM verification error during softwaretransfer from NIOS IDE via jtag. I don't see the relationship between FPGA-LVDS (3R) pins, and the read-write process of SRAM. Do you know, how i kann find the cause of this problem?Link kopiert
2 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It may be a signal integrity problem. If the design was changed, also a timing issue.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
ok, thanks.
but, what can i do agains signal integrity problems? i have to use this "time Quest" analyser to found/fix the problem?
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
