21612 Discussions
Gate Level Simulation for a specific block in the hierarchy
Lets say I have a design with a hierarchy down in the order A->B->C->D, where A is the top level, properly constrained and with proper pin settings.
What I want to do, is to keep the C as the top level, and to do a gate level simulation of the blocks C to D. The problem I m facing is that
C as a userlogic block has multiple ports with width = 256. Gate level simulation needs fitter to complete, as it needs timing file. Once keeping C as the toplevel file and if I compile the design, fitter fails and reports that total ports exceeds total available pins.
Any directions on how to proceed further would be quite helpful.
Jeebu Jacob Thomas
you can assign ports of your C block as virtual pins in assignment editor. This way fitter will make ports of your module as a logic elements not physical device pins.
