21615 Discussions
General question about Soc CycloneV and ARM with or without linux.
Hi every boby,
a naive question, is it possible to use a cycloneV SoC with ARM without linux.
With Nios, it is OK an OS or RTOS is not necessary.
I haven't found the answer yet.
Thank you to help.
Garfielminou.
Yes! In fact, if you install SOC EDS, it comes along with a ton of libraries to help you code in baremetal, and examples. There are also examples here: https://www.altera.com/support/support-resources/design-examples/soc.html
With Nios, it's also perfectly acceptable to code in baremetal. There are examples included in the Nios II EDS that comes installed in Quartus.
Hi SusannahM,
Tank you for your help.
I am going to follow your advice.
Garfielminou.
