Programmable Devices
21591 Discussions
General questions about memories, configuration and FPGA systems.
I have done some research on the forum about the topic, but i have still some questions and want
to verify and sum up everything. In my questions about system configuration i will refer to Cyclone III
device family.
1. Some memories questions:
1a. Regarding SRAM memory for NIOS II code. I have seen people using two chips with 16 buses in
parallel giving 32 bit bus. I haven't verified that, but is NIOS II using 32 bit instructions ? So it would be
most efficent to use it like that. What about using only one chip ? Does it mean that NIOS would have
to read the memory two times - so the code could be executed slower ?
Also on this forum couple of people suggested for that not using A0 of the SRAM chip address.
I was looking for SRAM chips on digikey with 32 bit data bus already - they are quite expensive.
That's why it is better to use two 16 bit chips?
1.b. Is external SRAM memory with 10ns access time really much slower that for example internal
on-chip sram with 100 MHz clock?
1c. Regarding FLASH memory. There are two main types of flash NANDs and NORs. As farest i know
NAND have to be read/written in a page manner, while NORs can be accessed directly at desired
address. Is it always better to use NORs with FPGA? Or is there a purpose for using NANDs?
1d. What about the main difference between SRAM and DRAM ICs. I know that:
- SRAM usually has 6 transistors, and DRAM is one MOSFET + capacitor - so it's cheaper.
- SRAM doesn't have to be constantly refreshed so it consumes less power.
- And last thing that - please correct me if i'm wrong: SRAMs are faster, that's why they used as a
cache memory, but ultimately DRAM synchronous clock, bursts allow for higher bandwidth ?
1e.Is with those other memories the same consideration about NIOS 32 bit bus and instructions?
2. System configuration.
I have found out that EPCS configuration memories are quite expensive, that's why people usually
don't use them, right ?
Let's stick for a while with that memory anyway.
2a. I have read Cyclone III documentation regarding configuration. Active Serial is used with EPCS
chips. I read the remote configuration part, and it seems that i can store as many configuration files in
the epcs as i want. If the time comes i can using NIOS or my custom logic to reconfigure FPGA with
a different code, configuration. The documentation suggested that the address for the memory
configuration to start with is at the beginning of the EPCS.
"When used with configuration memory, remote update mode allows an application
configuration to start at any flash sector boundary."
Is that correct ?
2b. In the same documentation there was also smth about that configuration memory can mean not
only EPCS device but also parallel flash memory.
Does it mean that for example instead of using expensive EPCS i could use cheaper NOR flash or
what kind of flash ? and that i could have the same functionality, with remote configuration etc. using
Active Serial?
Ok just right now i have found here
http://www.altera.com/support/devices/configuration/cfg-compare.html
that it can be used, and it's called AP. And that it needs CFI flash.
Any traps here?
2c. Can i in the same CFI Flash memory hold both more conifguration files and the code for NIOS II ?
There are some NIos commands like:
sof2flash, elf2flash, nios2-configure-sof,nios2-flash-programmer. Using those commands i can put
everything that i want in that flash in different address space?
It simply needs the pinout for FLASH and it knows how to use it?
I can use for the connection FPGA GPIO?
2.d In case of having nios code in the same FLASH, i should simply give NIOS the addres of the
beginning of the code for it in FLASH as a Reset Vector.
2.e. I haven't found that out - how is the code then copied to run from SRAM (for faster execution) -
Because i can assume that it could be run directly from that flash.
2.f. Before i started to write this post i was thinking about using some microprocessor to program the
FPGA using PS or FPP. I wanted to use some FLASH memory to store all different configurations for
the FPGA, and mircoprocessor would simply read the FLASH and program the FPGA.
I could use UART, USB or any different protocol i can come up with to upgrade for example the FPGA configuration
automatically.
However FPGA can receive data, reprogram the CFI Flash and reconfigure itself.
So correct me if i'm wrong but there is really no need for external uC?
Thanks for any answers to my questions, please address them by points and feel free to write some
other stuff that i should consider, read documentation etc.
best regards,
madness
tl;dr
but for first question:
since Nios II is 32bit CPU, then it is much better to use 32bit memory bus. I've tested 16bit and 32bit SDRAM solutions and the 32bit one is way much faster than 16bit... I couldn't achieve more than 100MHz Nios II CPU speed using 16bit memory bus.
It wasn't that long Socrates :) It's a general discussion part of the forum, so i posted all questions that i have,
divided them in related parts, gave them numbers for more clearity - not a bunch of text that would be hard to address.
How the instructions read is performed by NIOS in case of 16 bits ?
And i'll repeat my last questions, because i would really need to verify that.
Could I use CFI Flash for configuring automatically the FPGA and store different configuration codes and when needed start with different one ?
Is it possible to store there also the code for NIOS that would be copied to SRAM or SDRAM? How copying is done?
best,
madness
--- Quote Start ---
--- Quote End ---
AFAIK yes. Check how's the design made on Cyclone III development kit.
--- Quote Start ---
--- Quote End ---
AFAIK yes. You create a small bootloader, which runs from on-chip ram (Your reset vector must point there). Then that bootloader copies data from flash to sram/sdram and jumps to that address.
Thanks Socrates,
Is there anything that i must watch for when choosing DRAMs?
For example i have seen that DDR Controllers have a specific memory parts to choose - i was trying to find one on Digikey - even if they are on the list, the stack is 0.
Can i buy any memory, and then in DDR Controller choose one memory and adjust timings for the one that i bought?
best,
What Socrates wrote is correct. I only add some extra info.
Regarding the subject of storing different configurations/Nios-software into flash, you may read Altera application notes AN458 and AN521, or simply search the website for anything related to Remote Update.
In case you need to select one of the configurations stored in flash, the way of operation is actually this:
FPGA always starts with a base configuration (usually referred to as 'factory'), which is stored at address 0 of configuration device (i.e. epcs or CFI)
This is usually a non-fully operational firmware which only purpose is to boot the real application, user selected by means of dip switches, buttons, serial port command or any method you choose.
The base configuration sets up the remote update core for a fpga reconfiguration using an image at the desired flash address.
Only after this step the actual configuration becomes operational.
--- Quote Start ---
Thanks Socrates,
best,
--- Quote End ---
Depends on FPGA. SDRAM is the easiest: You can route it to any pins You want, the controller core is really small. DDR and DDR2 is harder, because there are only dedicated pins for DQ/DQS pins and controller cores are damn huge. DDR3 is not supported by Cyclone III.
Regarding the memory width question, You can use a 32, 16 or even 8 bit memory width (this applies SRAM, SDRAM or Flash). But since Nios is 32bits, it will require respectively 1, 2 or 4 memory accesses to fetch a single instruction or data. That's why a 32bit wide device is faster.
Regarding the differences between sram and sdram, you correctly remarked that sram are asynchronous, so they usually require adding wait states in order to meet the timing. This will reduce the throughput compared to sdram, especially in burst.
On the other hand sdram are slower in case of random access, because of the cumbersome access method (rows, columns, RAS, CAS, precharge ...)
thanks you both for the replies.
1. So i can connect CFI Flash, SRAM, SDRAM to any pins that i want.
Is there any consideration about using the sam IO bank for the one type of memory ? Or it doesn't matter?
2. Thanks Chris for the application notes, i'll read them both. Does it mean that the
base configuration can be rather small containing remote update core, so it gets loaded fast and
custom logic can read the FLASH in a specififc address (where is the info about what configuration at what address to load), and then the core would use that info and start the application.
I suppose that it wouldnt be much longer than using Passive Serial method?
Every new configuration would have to contain also the remote update core, so when the user wants to change the configuration (or simply change the functionality) it could be also be done from the that point. I would have to before reconfiguration write the FLASH memory with the new address for configuration in case of power supply being shut off.
3. Can i choose any specific chip of DDR, DDR2 if i'm able to meet the timing constraints ? I suppose that here would be the best to use the fastest speed grade FPGA for that kind of memory.
4. Cris how will the NIOS know if it has to read the memory for times. Is it smth that can be set in Qsys system ?
I have copied this from the forum:
"When using external SRAM with 32 bits interface one doesn't use A0 and A1 addresses.
When using extrenal SRAM with 16 bits interface one doesn't use A0 bit of the SRAM address."
Where and in what cases i should consider such connections?
Once again thanks for the replies,
best,
madness
It is also worth pointing out that all read cycles done by the nios cpu assert all 4 byte enables, the unwanted bytes are discarded internally.
Write cycles will assert the 'correct' byte enables. However if a byte write is done to an 8-bit slave the 'fabric' will always generate 4 write cycles - 3 of which will have the (single) byte enable inactive.
--- Quote Start ---
--- Quote End ---
Hi Dsl,
I don't really understand those memory byte enables.
If i wanted to use memory with 16-bits i could really simply tie those to correct values and never use them again ?
If i wanted to use the memory with 8-bit data i could use those byte enables to:
1. Select the lower byte - write the data at address 0
2. Select the higher byte - tie the data at address 0
3. Select the lower byte - write the data at address 1
4. Select the higher byte - tie the data at address 1
So it would effectively change the memory organization. But those byte enables are only masks, as i suppose they are only for the reason to not
change the higher/lower word when connecting with 16-bit data line.
Are normal memory controllers for 8-bit 'fabric' chips as you say, able to use effectively
16-bit memory ? Because those byte enables are only for masking data. When connecting 8 bits to D[0..7] of memory i'm able to
write only to lower bytes. Those bytes enables normally are not for routing the data internally in memory chip. So when connecting to 8-bit to 16-bit memory those bytes enables really doesn't matter, right?
Are there any other usage for byte enables? The same concept would be in DDR memories?
best regards,
madness
The byte enables are there so you can have interfaces that are 16 or 32 bit wide and still retain the ability to address individual bytes.
NIOS has a 32 bit wide master interface. When it executes an 8 bit store instruction, it will automatically set the correct byte enables, along with the target address.
If you only have an 8 bit or 16 bit wide memory bus, the memory controller shall also have an 8 or 16 bit wide slave interface.
In this case, the Avalon fabric will make the adaptation between NIOS' 32 bit interface and the memory controller's 8 or 16 bit interface and everything will work correctly.
What dsl was trying to convey is that the fabric will handle the conversion in less than 100% efficient manner.
--- Quote Start ---
--- Quote End ---
thanks rbugalho for the anwser, will it take for the NIOS 2 clock cycles instead of 1 to read the 32 bits from 16 bit memory, or there
is something else also to the effiicency loss?
best
Madness
Yes, a 32 bit read/write from a 16 bit memory will take 2 cycles. That's pretty much a given.
But even if the instruction only wants to read 8 or 16 bits, NIOS will perform read 32 bits, using two 16 bit accesses to the memory controller.
And even if the instruction only wants to write 8 or 16 bits, there'll be two 16 bit accesses to the memory controller, with the byte enables being used to only write the intended address.
That's the extra inefficiency.
The 16bit read will take an extra cycle (I think it is only 1, but it might be more - I avoid the bus width adapters if possible).
The nios cpu always stalls while doing an avalon cycle, the minimum delay is 2 clocks - so the instruction takes 3 clocks + any 'late result' stalls if the value read is used in the following 2 instructions. Reads from off-chip memory will be significantly slower (writes can be 'posted' and complete in later clocks).
The Nios cpu itself doesn't have an option to 'post' Avalon writes.
Accesses to tightly coupled data memory do not stall - except for a single clock stall for a write immediately following a read to the same tightly coupled memory block.
just recently i found memories connections explained in LPC43xx datasheet.
I attach the part of documentation regarding the topic. Hopefully somebody will find it useful.
madness
--- Quote Start ---
--- Quote End ---
EPCS is not the only devices you can use; people substitute with "generic" serial flash devices like M25 family from ST.
This blog summarizes, but is badly out of date cost-wise:
http://fpgaforum.blogspot.com/2006/03/any-replacement-for-altera-epcs_19.html
--- Quote Start ---
--- Quote End ---
Hi Ted,
That really makes sense. Yea the differece is quite big for EPCS16 and equivalent generic ST device (~14$ to ~1$).
Thanks for the TIP !
best,
madness
Hi Ted,
I have bought M25P16 and replaced EPCS16 with it and hell yeaa that works great.
It's really substituting ~14 $ chip with ~1 $ one ! (digikey prices for one part). For EPCS64 and M25P64 the ratio is even greater - 32,5 $ compared to 3 $.
That really gives quite big memory range for lots of configurations with altera remote update.
I scoped the data clock of the memory when configuring the cyclone II, it was about 12,5 MHz.
I wasn't able to find any info about speeding that clock for EPCS devices. Memory itself says that it's max. clock is 75 MHz. The EPC (enhanced) chip was reffered to have variable data clock. Don't really know the difference between EPC and EPCS devices.
There are also EPCQ (quad SPI) devices. I have installed the newest Quartus II 12 lately and they were there. As farest i know they weren't available in older version of Quartus. There is a big chance that Altera used here also 'generic' quad SPI flash as their EPCQ, so one could also substitute that.
best regards,
madness
