21592 Discussions
Generate EP3C55F484 Post-Configuation BSDL Model
FAPIOU
I'm developing JTAG tests for a PWA that uses a FPGA EP3C55F484 LVDS IOs; The standard BSDL model of EP3C55F484 doesn't have the Differential functionality.
I found a document 'BSDL_Files_Generation_in_QII.doc' that explains how to generate using Quartus Altera development SW. I have followed the instruction: After a full compilation with EDA_Tools_Setting and selection of Post-configuration BSDL file, there is no BSDL file generated.
I also found a tutorial on Youtube but for another FPGA family.
I'd appreciate if someone can share his/her experience in generating Post-configuration BSDL file for EP3C55 family device.
Thanks and regards,
Francois APIOU
Sebastian_M_Intel
Hello FAPIOU,
We would like to inform you that we have a forum for these specific issues and products, so we are moving it to the "Programmable Devices" forum so you can get better support for this matter.
https://community.intel.com/t5/Programmable-Devices/bd-p/programmable-devices
Sebastian M
Intel Customer Support Technician
JohnT_Intel
You may refer to https://www.intel.com/content/dam/altera-www/global/en_US/others/download/board-layout-test/bsdl/BSDL_Files_Generation_in_QII.doc in order to generate the post-configuration BSDL file.
Or use TCL file (https://www.intel.com/content/dam/altera-www/global/en_US/others/support/devices/bsdl/Generate_BSDL.tcl) to generate the BSDL file.
If you are still facing issue generating the file, then could you provide me your Quartus report file.
