21611 Discussions
Gigabit ethernet auto-negotiation fails
I am currently starting up my new board which has a Cyclone4 and a Micrel KSZ9021RL PHY. The problem is that I can't get the auto-negotiation working. If I disable auto-neg and force the speed to 10MBPs then there is a connection to my PC.
When I read the MIIM registers then I notice (with auto-neg enabled) that the 'link partner auto-negotiation able' bit is toggling. I think that the auto-negotiation algorithm is restarting all the time.
Has anybody had similar problems? In the forum I found one post of somebody having a similar problem but he used the wrong magnetics, I am using the magnetics advised in the datasheet (H5007NL).
thanks and best regards,
Karel
I am encountering the same problem. Were you able to solve the issue and are you willing to share the solution?
Thanks in advance,
Bert
