Good Day.
I am Trying to remove some warnings comming from I dont know where. Regarding the (altera_reserved_tck) On The Timequest, I see this. Info: Evaluating HDL-embedded SDC commands Info: Entity dcfifo_api1 Info: set_false_path -from *delayed_wrptr_g* -to *rs_dgwp|dffpipe_ed9:dffpipe16|dffe17a* Info: set_false_path -from *rdptr_g* -to *ws_dgrp|dffpipe_fd9:dffpipe19|dffe20a* Info: Entity dcfifo_psk1 Info: set_false_path -from *delayed_wrptr_g* -to *rs_dgwp|dffpipe_gd9:dffpipe6|dffe7a* Info: set_false_path -from *rdptr_g* -to *ws_dgrp|dffpipe_hd9:dffpipe9|dffe10a* Info: Entity dcfifo_s0j1 Info: set_false_path -from *delayed_wrptr_g* -to *rs_dgwp|dffpipe_vu8:dffpipe17|dffe18a* Info: set_false_path -from *rdptr_g* -to *ws_dgrp|dffpipe_0v8:dffpipe20|dffe21a* Info: Entity sld_hub Info: set_clock_groups -asynchronous -group {altera_reserved_tck} Info: create_clock -period 10MHz -name altera_reserved_tck [get_ports {altera_reserved_tck}] Warning: At least one of the filters had some problems and could not be matched Warning: altera_reserved_tck could not be matched with a clock Warning: Ignored assignment: set_clock_groups -asynchronous -group [get_clocks {altera_reserved_tck}] Warning: Argument -group with value altera_reserved_tck could not match any element of the following types: ( clk ) What is wrong on it? or how can I solve it? Where are this HDL-embedded SDC commands read from? Can I modify them? is it needed? or better do not play with them? anyway. What would U recommend to avoid this warnings? I allready try inserting in the project .sdc file the altera_reserved constraints generated from the Template but still not going away. Thankyou!Link Copied
what version of software are you using?
Quartus v 9.1
Could it be that the compiler did some optimization and removed/renamed the source/destination of the set_false_path path? So the TimeQuest could not find the path in the post-synthesis netlist and gave out the warning.
I saw such warnings in my project too and It never causes any problem. Tried to manually find the source/destination node using the exact filter statement and one of the source/destination node was actually missing.
