21611 Discussions
HELP, how to store data into the memory(example flash or any memory on my fpga
Topic: HELP, how to store data into the memory(example flashor any memory on my fpga dev kit) and read out the data when needed
Example my is data is 4 bit
0110, 0111,0000……
Anyone can advise me how to start? Any tutorial online canshare? Any mega wizard plug-in
Current using the Cyclone v GX fpga dev kit & quartus IIweb package 13 software
Thanks J
you want to store data from the NIOS to the Memory or from your own hardware?
--- Quote Start ---
--- Quote End ---
Cyclone V chip to the 512 MB flash memory. All is build inside the Dev kit board. no external HW
Okay, you want to store data to the 512Mb Flash Device.
But from where?
From your own Hardwareblock in the FPGA or from the NIOS?
With NIOS II, which is a processor, from Altera Quartus, that you can "build" in your FGPA. It is quite easy to write to flash and read back.
It is easier with your Altera dev kit. There are examples of NIOS II software that you can modify for that. Look at your "getting started" book included with your dev kit
in pure hardware (no processor), it is a little bit difficult : you have to handle sectors, to respect the timing of writing to flash...
--- Quote Start ---
But from where?
--- Quote End ---
from NIOSto Flash. is there any example of note on this parts for me to start.
See here:
http://www.altera.com/literature/hb/nios2/n2sw_nii5v2.pdf
starting at page 6-20
--- Quote Start ---
See here:
--- Quote End ---
just to check, can i use quartus II to write? what is the different between nios II and quartus II. sorry for asking lousying question cos i new to it.
thanks
Maybe you should watch some web seminars from altera to understand all this things...
FYI: QuartusII is the Software where you can Write your own VHDL/Verilog/etc Code and where you synthesise this code to get this HW-Description to your FPGA.
NIOSII is a Softcoreprocessor which acts like a "normal" Microprocessor but which is in the FPGA if you put him there...
