21588 Discussions
Hard memory controller / phy startup problem on A5GX
I'm having trouble running a DDR3 controller with HMC on an Arria V GX. The IP simulates well, but on the FPGA, it
seems to hang when the Sequencer (s0) tries to write to the PHY through the AVL interface (see attached screenshot).
Hardware: Arria V GX Starter Board (5AGXFB3H4F35C5ES)
Software: Quartus 13.1
Main VHDL file of generated DDR3 controller IP is attached.
Do you have any ideas?
