Programmable Devices
21613 Discussions
Has anybody ever write data to ssram on C3-starter-kit using vhdl?
I am using a 10M sram_clk to write data to the ssram on C3-starter-kit board.
The inside clk has a 180 degree phrase compared to sram_clk.
I wrote data in single cycle and read in three cycles.But what i got from the read in register is not what i expected.
I can not find error in my code.Can anybody help?This has been bothering for a week.Thank you.
The attached file is the stp file.
module memory
(input wire iCLK_50,
output reg [18:0] oSRAM_A,
output reg oSRAM_ADSC_N, // controller address status
output wire [ 3:0] oSRAM_BE_N, // byte write enable
output wire oSRAM_CE1_N, // chip enable
inout wire [31:0] SRAM_DQ,
output reg oSRAM_OE_N, // output enable
output reg oSRAM_WE_N , // write enable
output wire LED1,
output reg LED4 = 1,
output reg [31:0] DATA_TMP,
input wire KEY4,
input wire rst );
reg SRAM_D_ena;
reg [31:0] SRAM_D;
reg [3:0] state;
reg [3:0] key_state;
reg [18:0] wp;
reg [31:0] data;
assign SRAM_DQ = SRAM_D_ena ? SRAM_D : 32'hZ;
assign LED1 = (DATA_TMP == 32'h00000006) ? 0 : 1;
assign oSRAM_BE_N = 4'd0;
assign oSRAM_CE1_N= 0;
always @(posedge iCLK_50 or negedge rst) //siginal tap trigger
begin
if(rst == 1'd0) LED4 <= 1'b1;
else
if(KEY4 == 0) LED4 <= 1'b0;
else ;
end
begin
if(rst == 1'd0)
begin
state <= 4'd11;
wp <= 32'd0;
DATA_TMP <= 32'hz;
SRAM_D <= 32'h00000000;
SRAM_D_ena <= 1'b0;
oSRAM_ADSC_N <= 1;
oSRAM_WE_N <= 1;
oSRAM_OE_N <= 1; // close the SSRAM DQ drivers
SRAM_D_ena <= 1; // be ready for writing
end
else if (LED4 == 1'b1) state <= 4'd11;
else
case (state)
11: begin
oSRAM_ADSC_N <= 0;
oSRAM_A <= wp;
oSRAM_WE_N <= 0;
wp <= wp+ 32'd1;
SRAM_D <= SRAM_D+1; // WRITE!
state <= 1;
if(wp<6)
begin
state <= 11;
end
else
begin
state <=1;
end
end
1: begin // wait a cycle just in case
state <= 2;
SRAM_D_ena <= 0; // Turn off the drivers
oSRAM_WE_N <= 1;
end
2: begin // issue read
oSRAM_ADSC_N <= 1; //single read
state <= 3;
oSRAM_OE_N <= 0; // Open the SSRAM drivers
oSRAM_A <= 32'd2; //choose an address : 1
end
3: begin
state <= 4;
end// READ latency
4: begin
state <= 5;
end// READ latency
5: begin
// receive data
DATA_TMP <= SRAM_DQ; // READ!
state <= 6;
end
6: begin
state <=6;
end
default: state<=6;
endcase
end
endmodule
I haven't checked the datasheet, but shouldn't you keep ADSC low for one more cycle so that the SRAM gets your new read address?
--- Quote Start ---
--- Quote End ---
Thank you,Daixiwen
Yes,i got right data when i keep ADSC low before read.
The ADSP_n is pull up to high.I thought i could use single read model,but not.I got right at pipelined read model.
