21611 Discussions
Hello, I'm using a Max V cpld on quartus, I tested my code on quartus with modelsim, it's working...and now I'm working on dev kit Max V but I didn't have any result... my question is how i can put my test bench on dev kit ( cpld) thank you
OABBA1
Vicky1
Testbench module is defined without ports & used for functionality check/simulation of the design(using simulation tools) which is defined with input & output ports so compile the design, perform pin assignments & generate programming files for the design using full compilation & eventually load into the kit.
please refer the below link for reference.
https://www.youtube.com/watch?v=j5RGAW72o6A
Vicky
OABBA1
Thank you
I already did all this things but I don't have any result on my scoope
Vicky1
Could you please elaborate more about your observation with below points?
  1. pin assignment for clock, IOs etc
  2. successful compilation/programming file generation
  3. Device detection & successful program in Intel programmer
  4. observation of status LEDs.
Vicky
Vicky1
Have you resolved the issue?
May I know any update or Should I consider that case to be closed?
Vicky
OABBA1
the issue in not resolved I don't know the problem where I tried everything...all the point that you listed is done.
thank you
Vicky1
"Hi,
Vicky" ------------- it`s difficult to support without your inputs & observation so if possible provide at least all screenshots.
Vicky
OABBA1
Thank you!
here it's my program :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY pwm1 IS
 GENERIC(
   sys_clk     : INTEGER := 100_000_000; --system clock frequency in Hz
   pwm_freq    : INTEGER := 600_000;  --PWM switching frequency in Hz
   bits_resolution : INTEGER := 8;     --bits of resolution setting the duty cycle
   phases     : INTEGER := 4);     --number of output pwms and phases
 PORT(
   clk    : IN STD_LOGIC;                  --system clock
   reset_n  : IN STD_LOGIC;                  --asynchronous reset
   ena    : IN STD_LOGIC;                  --latches in new duty cycle
   duty   : IN STD_LOGIC_VECTOR(bits_resolution-1 DOWNTO 0); --duty cycle
   pwm_out  : OUT STD_LOGIC_VECTOR(phases-1 DOWNTO 0));     --pwm outputs
   --pwm_n_out : OUT STD_LOGIC_VECTOR(phases-1 DOWNTO 0));     --pwm inverse outputs
END pwm1;
ARCHITECTURE logic OF pwm1 IS
 CONSTANT period   : INTEGER := sys_clk/pwm_freq;           --number of clocks in one pwm period
 TYPE counters IS ARRAY (0 TO phases-1) OF INTEGER RANGE 0 TO period - 1; --data type for array of period counters
 SIGNAL count    : counters := (OTHERS => 0);            --array of period counters
 SIGNAL  half_duty_new : INTEGER RANGE 0 TO period/2 := 0;       --number of clocks in 1/2 duty cycle
 TYPE half_duties IS ARRAY (0 TO phases-1) OF INTEGER RANGE 0 TO period/2; --data type for array of half duty values
 SIGNAL half_duty  : half_duties := (OTHERS => 0);           --array of half duty values (for each phase)
BEGIN
 PROCESS(clk, reset_n)
 BEGIN
  IF(reset_n = '0') THEN                         --asynchronous reset
   count <= (OTHERS => 0);                        --clear counter
   pwm_out <= (OTHERS => '0');                      --clear pwm outputs
  -- pwm_n_out <= (OTHERS => '0');                     --clear pwm inverse outputs
  ELSIF(clk'EVENT AND clk = '1') THEN                   --rising system clock edge
   IF(ena = '1') THEN                          --latch in new duty cycle
    half_duty_new <= conv_integer(duty)*period/(2**bits_resolution)/2;  --determine clocks in 1/2 duty cycle
   END IF;
   FOR i IN 0 to phases-1 LOOP                      --create a counter for each phase
    IF(count(0) = period - 1 - i*period/phases) THEN            --end of period reached
     count(i) <= 0;                             --reset counter
     half_duty(i) <= half_duty_new;                     --set most recent duty cycle value
    ELSE                                  --end of period not reached
     count(i) <= count(i) + 1;                       --increment counter
    END IF;
   END LOOP;
   FOR i IN 0 to phases-1 LOOP                      --control outputs for each phase
    IF(count(i) = half_duty(i)) THEN                    --phase's falling edge reached
     pwm_out(i) <= '0';                           --deassert the pwm output
     --pwm_n_out(i) <= '0' after 100 ns;                         --assert the pwm inverse output
    ELSIF(count(i) = period-half_duty(i)) THEN              --phase's rising edge reached
     pwm_out(i) <= '1';
 --pwm_n_out(i) <= '1' after 100 ns;                          --assert the pwm output
                                        --deassert the pwm inverse output
END IF;
   END LOOP;
  END IF;
 END PROCESS;
END logic;
OABBA1
OABBA1
I'm generating the compilation/programming file very well and the device is programmed via usb blaster
