21602 Discussions
[Help on VHDL] FATAL ERROR while loading design
Hi guys, I've just started learning VHDL for a week on my own so i'm still very new to it. I'm doing a practice on implementing a 4-bit parallel-out serial shift register.. My codings can be complied but it shows
" # ** Fatal: (vsim-3347) Port 'din' is not constrained.# Time: 0 ns Iteration: 0 Instance: /shiftreg File: /EDCP6/proj15/jianhua/vhdl/Lab3_compare.vhd Line: 5# FATAL ERROR while loading design " when i tried to simulate it. can anyone help me out with this?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity shiftreg is port (
din: in std_logic_vector; -- data in
clk: in std_logic; -- Clock
clr: in std_logic; -- Clear
pset: in std_logic; --Preset
q : out std_logic_vector(3 downto 0) -- output Q
end;
architecture rtl of shiftreg is
begin
process (clk, clr,pset)
begin
if (pset='0') then
q <= "1111";
elsif (clr='0') then
q <= "0000";
elsif (clk'event and clk = '1') then
q <= din;
end if;
end process;
end rtl;
Trydin: in std_logic_vector(3 downto 0); -- data in
The error message tells you that your port din doesn't have a defined size. AFAIK unconstrained arrays can't be used on ports.
Hi daixiwen (http://www.alteraforum.com/forum/member.php?u=4443)! Thanks for replying my thread.
I realised i had left out the input length but for my case, i have a 2-bit input (AND gate) and it does not match with the 4-bit output!
Instead i tried forcing my inputs to a LOW but then again i realised, i need to be able to switch my input to a HIGH too. Any idea on what should i do?
din1: in std_logic_vector:="0" ; din2: in std_logic_vector:="0" ;
This was what i did but i couldn't force it a high when after simulating it! What should i do? :confused:
why have you declared a std_logic_vector of only 1 bit? you really should give it a fixed length, otherwise its really just a std_logic
If you need to change the value during simulation, you should write a testbench.
Your post here is not very clear. If you have a 4 bit output, you need to connect all 4 bits to something.
Thanks for the help Tricky! I got it working now.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity shiftreg is port ( A: in std_logic; -- data in B: in std_logic; clk: in std_logic; -- Clock clr: in std_logic; -- Clear preset: in std_logic; --Preset q : out std_logic_vector(3 downto 0) -- output Q ); end; architecture rtl of shiftreg is signal q_int : std_logic_vector(3 downto 0); begin process (clk, clr,preset) begin if (preset='0') then q_int <= "1111"; elsif (clr='0') then q_int <= "0000"; elsif (clk'event and clk = '1') then q_int(0) <= A and B; q_int(1) <= q_int(0); q_int(2) <= q_int(1); q_int(3) <= q_int(2); end if; end process; q <= q_int; end rtl;
Bu how do i write a test bench? I tried writing one myself i think it's pretty messed up and it doesn't seem to produce the waveform i wanted.
Testbench
Library IEEE; Use IEEE.std_logic_1164.all; Entity shiftregTB is end; Architecture rtl of shiftregTB is signal A,B,clk,clr,preset: std_logic; signal q,q_int : std_logic_vector(3 downto 0); begin UUT : entity work.shiftreg port map(A,B,clk,clr,preset,q_int); tb : process begin preset<='0'; wait for 10 ns; preset<='1'; wait for 10 ns; clr<='0'; wait for 20 ns; clr<='1'; wait for 20 ns; clk<='1'; wait for 20 ns; A<='1'; wait for 30 ns; B<='1'; wait for 30 ns; A<='0'; wait for 40 ns; B<= '0'; wait for 50 ns; end process tb; q<=q_int; end;
your test bench is a good starting point. It is usually easier to generate the clock in a separate process and concentrate on the other signals in your main test bench process.
What are the differences between what you want and what you get?
