21602 Discussions
SOPC Cyclone 3 starter board
Hi all,
I have this attached design
when i run nios2-download zImage :
--- Quote Start ---
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 1424KB in 26.6s (53.5KB/s)
Verified OK
Leaving target processor paused
--- Quote End ---
when i run nios2-terminal
--- Quote Start ---
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 5-1.2]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
--- Quote End ---
After nothing appears on my screen !!!!
thanks for help
you need to add the -g option to nios2-download to start the processor after the image upload
Thank you very much
It s ok now :)
