21615 Discussions
Hi guys I am writing code for shifting rows section in an AES algorithm stuck getting errors.
CLyna
I am trying to create a matrix from a vector using for loops then mapping a matrix to move them to there required positions. but i keep getting the error Error (10028): Can't resolve multiple constant drivers for net "matrix1[15][4]" at sf.vhd(48)
This keeps occurring for all aspects of the array i have included a full script of the code. Thanks in advance. Ciaran.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity sf is
  Generic ( DATA_LENGTH : integer := 128 );
  Port ( data_out : out STD_LOGIC_VECTOR (DATA_LENGTH-1 downto 0);
      finish : out STD_LOGIC;
      data_in : in STD_LOGIC_VECTOR (DATA_LENGTH-1 downto 0);
      start : in STD_LOGIC;
      clock : in STD_LOGIC;
      reset : in STD_LOGIC);
end sf;
architecture RTL of sf is
  ----------- TYPES -----------
  TYPE matrix_index IS array (15 downto 0) OF std_logic_vector(7 downto 0);
  ---------- SIGNALS ----------
  SIGNAL matrix1, matrix2 : matrix_index;
begin
  -- Initialize and Reset process
  reset_n_init_process : process(reset)
  begin
    if(rising_edge(reset)) then
      for i in 15 downto 0 loop
        matrix1(15-i) <= (others => '0');
        matrix2(15-i) <= (others => '0');
      end loop;
    end if;
  end process reset_n_init_process;
  -- map the 128 bit input to matrix1 so we can shift it.
  vector_to_matrix1: PROCESS(start)
  BEGIN
    if(rising_edge(start) and clock = '1') then
      FOR i IN 15 downto 0 LOOP
      matrix1(15-i) <= data_in(8*i+7 downto 8*i);
      END LOOP;
    end if;
  END PROCESS vector_to_matrix1;
  -- matrix2 is actually matrix1 shifted as shown in the above example.
  -- combinatorial logic
  -- first column
  matrix2(0) <= matrix1(0);
  matrix2(1) <= matrix1(5);
  matrix2(2) <= matrix1(10);
  matrix2(3) <= matrix1(15);
  -- second column
  matrix2(4) <= matrix1(4);
  matrix2(5) <= matrix1(9);
  matrix2(6) <= matrix1(14);
  matrix2(7) <= matrix1(3);
  -- third column
  matrix2(8) <= matrix1(8);
  matrix2(9) <= matrix1(13);
  matrix2(10) <= matrix1(2);
  matrix2(11) <= matrix1(7);
  -- forth column
  matrix2(12) <= matrix1(12);
  matrix2(13) <= matrix1(1);
  matrix2(14) <= matrix1(6);
  matrix2(15) <= matrix1(11);
  --map matrix2 back to 128 bit vector
  matrix2_to_vector: PROCESS(matrix2)
  BEGIN
    if(clock = '1') then
      data_out(8*i+7 DOWNTO 8*i) <= matrix2(15-i);
      END LOOP;
      finish <= '1';
    end if;
  END PROCESS matrix2_to_vector;
end RTL;
sstrell
I think the problem is you have your reset and loading of matrix1 in two separate processes, causing multiple drivers into matrix1. The code should probably look like this:
process (reset, clock)
BEGIN
 if(reset) then
      end loop;
  elsif (start and rising_edge(clock)) then
      matrix1(15-i) <= data_in((8*i)+(7 downto (8*i)));
      END LOOP;
else matrix1 <= matrix1;
    end if;
end process;
#iwork4intel
