21602 Discussions
How can i estimate a .pof file size?
i'm doing a project with EP3C, and the PCB is small, so i have to use the smallest area of ecps in the pcb. I read the file"cyc3_ciii51016.pdf",in table 9-3, it lists the size of .rbf. I wonder what the relation between .pof and .rbf. And can i think it's the maximum size of the .pof without .hex and anything else, or the size is fixed ?
.rbf is the contents of the EPCS
.sof has some more stuff like a header.
To choose an EPCS device, all you need to know is the .rbf size. And if you use compression (available for free in EP3C FPGAs) it even gets smaller.
that means i can think the size is fixed?and is it just decided by what the model i use ?
If you don't use compression, the size is fixed for any given device.
If you use compression, it'll be smaller than the fixed size but will vary from design to design.
