21615 Discussions
How do I turn auto global clock signals off?
Hi again!
Does anyone know how to turn this off in Version 10? It's adding macrocells to my design that I just can't afford.
This system message:
Info: Promoted clock signal driven by pin "clk" to global clock signal
Thanks!
Actually, that website doesn't help at all. The option it specifies isn't there... :(
--- Quote Start ---
--- Quote End ---
open the Assignment Editor. Double click into the tab "Assignment Name" , choose "Global signal". Go to the value tab and choose "off". In the "to" tab you have to specify your signal. Using "*" should switch the global feature off. That should solve your
problem.
Kind regards
GPK
