21608 Discussions
How to Configure Cyclone IV to LVDS Clock Inputs
Hi, I would like to know how to configure my Cyclone IV design project for LVDS clock inputs. Usually the system clocks are single-ended inputs, but in my new design my system clocks are differential.
I've tried using the Assignment Editor property to assign CKN/CK to the input port symbol pin but after I compile the project and then back annotate it assigns the input port symbol pin to a signal-ended clock pin not to a differential pair pins.
If anyone can help I would greatly appreciate it.
joe
You need to set the I/O standard of the P side of the differential signal to LVDS. Quartus will then automatically assign the N side.
Cheers,
Dave
I just figured it out. It is in the Pin Planner. Thanks!
You can also use a Tcl constraint.
If the clock pin has an internal termination, you also need to set the termination constraint to "OCT 100 OHMS" (or whatever its called for a Cyclone IV. This is the Stratix IV name).
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
There's no differential OCT feature with Cyclone - Cyclone IV.
--- Quote Start ---
--- Quote End ---
Indeed :)
On page 114 of the Cyclone IV handbook PDF, Table 6-2, shows that there are no LVDS terminations.
C'mon Altera, how cheap!
Thanks for the pointer Frank. I'm thinking of using a Cyclone IV GX as a PCIe bridge in my next design.
Cheers,
Dave
