Programmable Devices
21615 Discussions
How to Design a Multiplier Circuit using AHDL?
Hi all:
I have a multiplier circuit built using Multisim and I suppoosed to use AHDL to implement the circuit. Problem is, I don't know where to begin and how to actually use the circuit. Here are the design parameters and the algorithms that I have.
Please the attached file. This is where I am getting stuck at. How do I actually write this into code?
Lew
Step 1: Go to your tutor and tell him that AHDL is an old and unsupported language. From Quarus 10 you wont be able to simulate it at all.
Step 2: Do it in a more modern HDL like VHDL or Verilog that are IEEE standard, not proprietry, languages.
Otherwise:
MultiplierA : lpm_mult WITH ( LPM_WIDTHA = 2 , LPM_WIDTHB = 2 , LPM_WIDTHP = 4 , LPM_WIDTHS = 1 , LPM_REPRESENTATION = "UNSIGNED" , LPM_PIPELINE = 1 , INPUT_A_IS_CONSTANT = "NO" , INPUT_B_IS_CONSTANT = "NO" , USE_EAB = "OFF" , DEDICATED_MULTIPLIER_CIRCUITRY = "YES" ) ; MultiplierA.clock = clk; MultiplierA.clken = VCC; MultiplierA.dataa = input1; MultiplierA.datab = input2; output = MultiplierA.result;
Understable Tricky,
However, these projects are for Digital Systems class and I think the purpose here is to get the understanding of PLD's and Programming down-packed. Not to actually use in a system. Can you explain what the device family is supposed to mean and how do you know which family and device to use with a particular circuit?
LEW
The device family is the chip you chose. And which chip you chose really depends on application.
If you want millions of gates and high-speed coms, you got for a stratix 4 ($thousands), if you need something cheap that can still do plenty you go for a cyclone 3 ($hundreds).
With modern devices as they all have plenty of memory and embedded multipliers, there are only 2 main deciding factors
1. Cost
2. Comms required
I get the feeling the question is aimed at much more outdated technology though.
