Could any one help me out on how to simulate ROM Megafunction, Actually I tried both by generating .hex as well .mif format , but I couldnot get the results. It is a single port ROM , With clock , address and q as signals,. When I simulate I see the outputs (q) to be zero every where. Is there any procedure to follow to read the actual values ??/ Hope any one respond and help me out .. Thanks, Srinath.Link Copied
A possible reason is that your initialisation isn't read. If so, it could be seen from a simulation warning. Generally *.hex is required for ModelSim, and must reside in ModelSim project directory, that's where the modelsim.ini and *.hdp project files are located. The ROM content can be examined also in simulation memory window.
Thanks for the reply... My results are up .... Thanks a lot for the immediate reply..- Mark as New
Hi.
I like to read and write data to SSRAM on the board . Could you please help me what are the timings that I should maintain for that ? Is there any document explaining how to do ?? I am using Nios II Evaluation Board (Cyclone III EP3C25F324N6) , I am stuck , s please provide me the information Thanks , Srinath.
