21602 Discussions
How to archive Quartus Project using commands promt (inside and outside of Quartus)?
Hi All,
1) How can I archive the Quartus Project from commands prompt?
2) How can I archive the Quartus Project externally (not from Quartus)? Let's say from a linux shell or using windows's *.bat file?
Thank you!
1) Refer to the "quartus ii scripting reference manual (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/tclscriptrefmnl.pdf)".
2) Use 'quartus_cdb' with the --hc_archive option.
Cheers,
Alex
When running the "quartus_cdb amp --hc_archive", I'm receiving the following error message:
Info: Command: quartus_cdb amp --hc_archive
Error (39003): Run Analysis and Synthesis (quartus_map) with revision "amp" for
--rev option before running Compiler Database Interface (quartus_cdb)
Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
So, what's the whole flow? Should I always run the quartus_map command before the quartus_cdb even the project was compiler, synthesized and mapped from the GUI?
Try:
quartus_cdb amp --hc_archive=my_archive
It should work with a project already compiled with the GUI.
Cheers,
Alex
