21611 Discussions
How to check eye diagram of transceivers on Cyclone V device?
Hi there,
How could I check eye diagram of transceivers on Cyclone V device? I searched from Google, there is an application note AN605 which is related to Straix device, is there a similar application note for Cyclone V?
Thx.
http://www.altera.com/products/software/quartus-ii/transceiver/swf-transceiver-toolkit.html
You can use the toolkit with Cyclone V but will not get the eye diagram info.
Hi resfton,
Thank you for the quick reply. I will try to play around with the toolkit.
Cheers
Hi cnie,
As I understand it, Cyclone V does not support EyeQ feature. Thus, you would not be able to plot 2D eye with XCVR toolkit. As a workaround, you might want to use scope to check the eye diagram.
