21611 Discussions
How to config MAXII with MCU
Hello everyone
Recently I want to config MaxII with MCU ,so can you give me some suggestion?
may be Jamplayer?or ?
Embedded JRunner should be a solution. Cause MAX II has flash configuration storage with limited number of reprogramming cycles, it must be programmed only in case of configuration updates.
you say JRunner ,but it can used in windows NT
I don't understand what you searching for. You have been talking of configuring from a MCU not from a PC. What is the role of NT with your MCU?
