Programmable Devices
21611 Discussions
How to confirm pin assignment for a cyclone chip with LVDS, SSTLII, 2.5v LVCMOS I/O?
Hi All,
I'm designing a FPGA project with cycloneIII.
Since we have to use LVDS input together with DDR(SSTLII classI) and 2.5v LVCMOS voltage level I/O. the minimum pin distance between LVDS and 2.5v LVCMOS must be guaranteed. So I create a vacant module with all I/Os instantiated.
My question is, is that ture that only if the compilaton can successfully pass that means the I/O assignment is ok?
Anyone who have similar experience can give out some advice?
Thanks !
--- Quote Start ---
--- Quote End ---
If compilation includes fitter process then yes, it is true.
A little tip: you can configure Quartus to check I/O assignments validity before full compilation is initiated. Go to Assignments->Settings->Compilation Process Settings and check "Run I/O assignment analysis before compilation". Or you can run this check directly from Processing->Start menu.
Thanks AndrewS6! That's great!
