I'm a little lost on how to connect these PLL_CLKOUT pins. The doc says "When not using these pins, connect them as defined in Quartus software." I was going to ground them and leave the default setting as Input Tri-Stated with Weak Pull-Up. Will that work?
Thanks for the help, newMeat1Link Copied
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
