Programmable Devices
21608 Discussions
How to create Separate System in Qsys Under IP Catalog ?
I am using Quartus web edition 14.1 (Free edition) for my trial purposes. I want to know how to create unique IP system in qsys under IP Catalog ? For your reference please find the attachment. Just like i need to create separate system in qsys.
Anyone can share me the flow in creating system under IP Catalog of Qsys.
As long as Qsys (now called Platform Designer) can "see" a .qsys file, it gets listed in the IP catalog. For it to see the file, it needs to be in the same directory as the current .qsys, in a directory named ip one level down from the current .qsys file, or in a custom location specified in the tool's options.
--- Quote Start ---
--- Quote End ---
Sorry, i am unable to get you what you trying to explain me :confused:
Please can you explain me step-by-step.
Check Intel Quartus Prime Pro Edition Handbook Volume 1 Design and Compilation
For “Create IP Components in the Platform Designer Component Editor” from the following link, & check screenshot.
https://www.altera.com/documentation/jbr1437426657605.html#mwh1409958782920
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
There's not much to explain. Where have you placed the .qsys file that you want to appear as a system you can add to another system?
This is called hierarchical system design, so there has to be an already completed system that you are adding as a component in another system.
