21615 Discussions
How to determine the <device_name> <aocx_file> for FPGA card
well
Dear intel team,
When typing <aocl diagnose> command.  The following sub-message appeared.
<BSP not loaded for Programmable Accelerator Card pac_f000000
* Run 'aocl diagnose' to determine device name for pac_f000000
* Run 'aocl program <device_name> <aocx_file>' to initialize BSP>
I want to Know how I can exactly determine device name and  aocx_file. in order to load BSP.
Bellow is the whole message:
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 2 icd entry at that location:
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
/etc/OpenCL/vendors/Altera.icd
the following OpenCL libraries are referenced in the icd files:
libintelocl.so
libalteracl.so
checking LD_LIBRARY_PATH for registered libraries:
WARNING: libintelocl.so NOT FOUND
libalteracl.so was registered on the system at /glob/development-tools/versions/fpgasupportstack/d5005/2.0.1/inteldevstack/hld/host/linux64/lib
Using the following location for fcd installations:
/opt/Intel/OpenCL/Boards
Found 1 fcd entry at that location:
/opt/Intel/OpenCL/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
/opt/intel/2.0.1/inteldevstack/d5005_ias_2_0_1_b237/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so
/opt/intel/2.0.1/inteldevstack/d5005_ias_2_0_1_b237/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 1
1. Intel(R) FPGA SDK for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
ICD diagnostics PASSED
BSP Diagnostics
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
Physical Dev Name Status Information
pac_f000000 Uninitialized OpenCL BSP not loaded. Must load BSP using command:
before running OpenCL programs using this device
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
well
Thank you intel team. I found the solution in this link here
David_G_Intel
Hello well
Thank you for posting on the Intel️® communities. Please remember to post FPGA requests on the correct sub forum, for future requests go to Browse Community Forums > FPGAs and Programmable Solutions then, post a question on the appropriate topic. We will move this thread now.
David G
