21602 Discussions
How to do dual config on MAX10
JSLY
How do I do a dual configuration on MAX 10 device not using JTAG,   we want to do remote device update over SPI,  it doesn't look like this is available?
JSLY
We do not have external QSPI and probably dont have room to have Nios Processor,  can this be done with a state machine and other logic,  meaning use state machine to copy incoming image to ram, then copy ram to flash with a state machine?
FvM
your approach is well feasible. You'll basically use the provided On-Chip Flash and Dual Configuration IP and implement everything else in user logic.
You don't necessarily need a RAM buffer, just write data to flash as it comes in. A FIFO might increase throughput though.
NurAiman_M_Intel
Hopefully you can now proceed with your design per the response from our friend previously.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
