Hi ,
I have latches (as combinational loops) which must be used in my design. These latches acts as start/end point for timing analysis. So my design is not getting properly optimized. Is there any way, i can ignore these latches from timing analysis & for synthesis/Fitter optimizations. I have tried False path/ disable timing constraints and it didn't work. Also tried switch -no_latch for timing but its not useful. Regards, NKDLink Copied
Hello ,
Can I guide tool to ignore latches as sequential elements. Either in synthesis or Fitter stage. Regards, NKD
Topic Options
