21615 Discussions
How to include custom onchip memory block into the Linker section mappings ?
Hello, I have a custom onchip memory (block memory) with a avalon slave interface. I want this to show up in the linker section mappings of eclipse SDK. So, that i will use this to load rodata,heap, stack (use it as code memory). I observed that on-chip memory has got attribute named "memory " and jtag-uart has got "printable" attribute. what additional things to do to my custom logic so that it can be seen in linker mapping section.
In the BSP editor, add it as a new section to the Nios memory map.
I tried it , but it says error something like- memory block withe the name "my custom logic" not found in sopc design. I explored the .IP file of onchip that taken from IP catalog and compared with .IP file of my custom logic. I can see there are certain .xml like lines in the ip file
Like IsMemoryDevice =1 in alteration ocm and it is zero in my case. I am thinking in this direction.
You need to edit your IP's *_hw.tcl file with a text editor. Find the section describing the Avalon Slave interface for your memory component, that should be like this:
# # connection point iname # add_interface iname avalon end (where iname is the name of your avalon interface)
And add a parameter in the list:
set_interface_property iname isMemoryDevice truereplacing iname with the name of your interface.
Then regenerate the QSys project and recompile.
--- Quote Start ---
--- Quote End ---
Hehe !!! Worked
This is exactly what I want
I can now select my peripheral in linker script pulldown menu. Trivial thing is ,In settings.html file attribute name is empty.
Thank you
