21611 Discussions
How to build object libraries and assembly Macro-Instructions libraries?
For bare-metal application I need to build libraries of object files and libraries of assembly macro-instruction.
I look for information in documentations but I could not find anything.
Thanks for your help.
Kind regards
Jerome
Hi Jerome,
Go through the online training.
https://www.altera.com/support/training/course/osocbarehwlib.html
Kindly refer to the link below
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_bm.pdf
It is probably helpful as you might be hoping.
Thanks a lot for your fast reply.
The online training courses cab help me a lot.
Today I’ve already created a start project with GCC compiler and ARM compiler.
I saw the HwLib in the following directory:
C:\intelFPGA_pro\18.0\embedded\ip\altera\hps\altera_hps\hwlib\include\hwlib.h
These libraries are made for c language and I suppose I will have to redistribute it in binary form.
But my question was different; I need to build my own macro-instructions libraries using an archived library (BFD ar-compatible for example). It seems that is possible with the GNU compiler but not with ARM compiler.
My question was; how to create an archived library of macro-instructions with the tools DS-5 AE. This library will be loaded by the .mlib directive of GNU assembler (for example).
Jerome
To create a new object library it necessary tu use ARMAR tools :
https://developer.arm.com/docs/dui0476/g/creating-libraries/creating-a-new-object-library
Once the library is made it's necessary to declare it in project property --> setting-->ARM Linker --> Libraries --> User libraries files.
Jerome
