21608 Discussions
How to manage CRC_ERROR pin through JTAG?
НЛоги
Hello.
I need to work with SEU in Arria 10.
I've installed EMR Unloader IP in my design and it works as expected.
I can make changes in EMR through JTAG (in-system sources and probes).
The problem is that I can't manage CRC_Error pin through JTAG. This is required to debug the external logic intended for SEU mitigation.
When I make changes to EMR through JTAG, CRC_ERROR pin remains low.
Please say, what can I do to manage CRC_ERROR pin? Best way is to change it syncronously with EMR.
I have no dedicated license for SEU IPs, so Fault injection IP and so on SW are not available for me.
Thank you in advance for any help.
Nooraini_Y_Intel
Hi НЛоги,
In order to test the CRC_ERROR pin you do require to use the Fault Inject debugger together with the Fault Injection IP. There is no method that you can inject the error via JTAG.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an737.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fault_injection.pdf
If you have Quartus Prime Standard license, you can try to check within the Self Service License Center submit the Contact Customer Service form at:
https://fpgasupport.intel.com/Licensing/license/contact.html
Otherwise contact your local Intel FPGA sales representative for the Fault Inject IP license.
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Thank you
Nooraini
