21606 Discussions
How to open the precompiled Quartus Prime project
Vladislav-Butko-bvo
I have precompiled (with db and incremental_db folders, so it have sof/pof files) Quartus Prime (22.1std.1 Build 917 02/14/2023 SC Lite Edition) project and want to open "Technology Map Viewer (Post-Fitting)" diagram without any changing in the project (in particular, whitout second compilation).
I attempt to open this project in Quartus Prime 24.1std.0 Build 1077 03/04/2025 SC Lite Edition.
While opening the project the follow warning is appearing:
"Do you want to overwrite the database for revision ...?"
If I click on "No" nothing more will happen. So, I click on "Yes".
This operation updates precompiled db folder. That's why need to import database (Project -> Import database) from original (without updates) project folder copied in advance of clicking "Yes".
While the importing I chose db folder from the original folder, but was occured the follow error: "*.db_info is up to date ...". I stuck on this stage...
FvM
24.1 involves many changes. To open the compiled database or recreate it almost identically (the fitter result can be slightly different due to random seed) use 22.1.1, still available for download.
FvM
