21597 Discussions
How to rename Project in Quartus-II?
Hi All,
How can I rename the Quartus-II project? Could it be done via GUI? By TCL command?
Thank you!
I have not seen such option as rename in GUI but you can rename your project by following these steps:
1. Copy project with different name Project -> Copy Project
2. Create new revision with diferrent name Project -> Revisions...
3. Delete revision with old name
Maybe there is other way to do this task but it works for me..
I've never tried it, but you might just need to edit the .qpf file and .qsf file in a text editor (and save those files with the new name). You'll probably have to trash the db folder and recompile, but I would think this would do the trick.
