21599 Discussions
Verify failed between address <> and <> Leaving target processor paused
Folks, I have the following simple SRAM circuit built using Qsys.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13281&stc=1
I then instantiated the circuit on a top level module and programmed the board.
entity SRAM is port( CLK: in STD_LOGIC; led: out STD_LOGIC; --to/from SRAM fsm_dq: inout std_logic_vector(15 downto 0); fsm_addr: out std_logic_vector(19 downto 0); sram_lb_n: out STD_LOGIC; sram_ub_n: out STD_LOGIC; sram_ce_n: out STD_LOGIC; sram_oe_n: out STD_LOGIC; sram_we_n: out STD_LOGIC ); end SRAM; Architecture Arch of SRAM is component SRAM is port ( clk_clk : in std_logic := '0'; -- clk.clk reset_reset_n : in std_logic := '0'; -- reset.reset_n sram_DQ : inout std_logic_vector(15 downto 0) := (others => '0'); -- sram_0_external_interface.DQ sram_ADDR : out std_logic_vector(19 downto 0); -- .ADDR sram_LB_N : out std_logic; -- .LB_N sram_UB_N : out std_logic; -- .UB_N sram_CE_N : out std_logic; -- .CE_N sram_OE_N : out std_logic; -- .OE_N sram_WE_N : out std_logic -- .WE_N ); end component; begin SRAM_MAP: SRAM port map( clk_clk=>CLK, reset_reset_n=>'1', sram_DQ=>fsm_dq, sram_ADDR=>fsm_addr, sram_LB_N=>sram_lb_n, sram_UB_N=>sram_ub_n, sram_CE_N=>sram_ce_n, sram_OE_N=>sram_oe_n, sram_WE_N=>sram_we_n );
When I programmed Nios for a simple Read/Write memory test operations, I keep getting verify failed between address 0x204200 and 0x20FFFF(which is the memory address space of the SRAM) error. I set the on-chip memory size to the maximum possible. I don't know what is wrong. Any idea?
Cheers,
You should change your bsd to use the onchip memory as the main RAM (for .text, .data, .bss and .head). Then you can generate a memory test application that will test the SRAM from there.
You can also add some Signaltap probes to the SRAM signals to check what the CPU is doing.
My onchip memory is the main RAM. I am using the Altera Monitor Program to program NIOS and here is the screen shot.
https://www.alteraforum.com/forum/attachment.php?attachmentid=13290
https://www.alteraforum.com/forum/attachment.php?attachmentid=13291
There must be something wrong then, because with those settings the Nios programmer shouldn't try to write to the addresses 0x204200 - 0x20FFFF. Are you sure you are using the correct bsp and that it has been recompiled?
