21611 Discussions
How to route output clock of alt2gxb to a pll?
The error information is
"Error: Clock input port inclk[0] of PLL "pllo:u_pllo|altpll:altpll_component|pll" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Info: Input port INCLK[0] of node "pllo:u_pllo|altpll:altpll_component|pll" is driven by siigx125_phyx1:phy|altpcie_serdes_2sgx_1x125:phypcsx1|alt2gxb:alt2gxb_component|rx_coreclk_in[0] which is CLKOUT output port of HSSI_TRANS type node"
I'd like to create additional x1 and x(1/2) in-phase clock based on alt2gxb:clk.
Thus, alt2gxb:clk is connected to a altpll module.
But it caused above error.
Please help.
Jimmy
The siigx handbook says, in the volume-2 page 7-73, "An internally generated global signal cannot drive the PLL". The clock output from the alt2gxb is always routed through global signal, so you can't do this.
Thanks for reply.
Its my first time to run altera fpga.
do you have any suggestions about my requirement?
best regards,
Jimmy
note, I try to output gxb clock outside fpga chip and connect it back to a clock pin , then
atlpll can generate x1 and x(1/2) in-phase clock. But timing between gxb:clk and pll:x1/x(1/2) clock cannot be check exactly.
I don't know if it meets your requirement, but the only way I can figure out is to use phase comp fifo in the gxb like handbook vol-2 page 2-131. I attached the sample.
Thanks!
