Maybe the title is not clear. Let me explain more. I have recently downloaded and installed the free version of Quartus 64 bit 2014.2 for Windows. Then, I opened a .VHD file. Quartus now opened VHD file successfully. Now I want to Analysis and Elaboration, then use State Machine View, but all of these buttons are grey (so I cannot press them). What should I do now? Thank you very much,链接已复制
9 回复数
--- Quote Start --- First of all, Quartus 14.2 doesnt exist. Are you sure it's not Q14.0? Secondly - you need to create a project before you can run those tools --- Quote End --- Hello The tool requires a device before I can create a new project. I have no idea on which device I can use (basically I have no physical one). Could you give me a hint?
just pick one. You can set this to auto, and in theory it can pick a device for you. The synthesis is different for each device family.
But usually you have an idea what device you're using before you start - based on factors such as boards available, cost, IO requirements etc.--- Quote Start --- just pick one. You can set this to auto, and in theory it can pick a device for you. The synthesis is different for each device family. But usually you have an idea what device you're using before you start - based on factors such as boards available, cost, IO requirements etc. --- Quote End --- Thank you very much Now I can compile and use RTL Viewer to see. But when I use State Machine Viewer, it showed nothing. Do you have any idea about this?
Actually, this code was not written by me, so I do not understand it's original purpose.
Maybe I am not an expert in model checking, but I think every piece of code can be converted to one (or more) corresponding state machine. Of course, this state machine may be a useless and ugly one, but valid
