21611 Discussions
How to start with Quartus 2014.2?
Maybe the title is not clear. Let me explain more.
I have recently downloaded and installed the free version of Quartus 64 bit 2014.2 for Windows. Then, I opened a .VHD file. Quartus now opened VHD file successfully.
Now I want to Analysis and Elaboration, then use State Machine View, but all of these buttons are grey (so I cannot press them).
What should I do now?
Thank you very much,
First of all, Quartus 14.2 doesnt exist. Are you sure it's not Q14.0?
Secondly - you need to create a project before you can run those tools
Sorry, it is my mistake.
yeah, I mentioned version 14.0
--- Quote Start ---
--- Quote End ---
Hello
The tool requires a device before I can create a new project.
I have no idea on which device I can use (basically I have no physical one). Could you give me a hint?
just pick one. You can set this to auto, and in theory it can pick a device for you. The synthesis is different for each device family.
But usually you have an idea what device you're using before you start - based on factors such as boards available, cost, IO requirements etc.
--- Quote Start ---
--- Quote End ---
Thank you very much
Now I can compile and use RTL Viewer to see. But when I use State Machine Viewer, it showed nothing.
Do you have any idea about this?
Maybe it didnt recognise a state machine.
Post your code.
Attached is my code
Usually, for a state machine, you would make the state a signal rather than variable, as well as leaving it as an enumerated type.
is there what you expect in the RTL diagram?
Actually, this code was not written by me, so I do not understand it's original purpose.
Maybe I am not an expert in model checking, but I think every piece of code can be converted to one (or more) corresponding state machine. Of course, this state machine may be a useless and ugly one, but valid
