21600 Discussions
How to switch arria10 calibration clock from usrclk pin to internal_osc?
Hi.
On our arria10 board, there is a mistake to make usrclk pin to be one DDR3's DQ pin. This would lead to transceiver not be able to be calibrated at POR and in user-mode.
We got one tcl script, which is expected to transfer the calibration clock source from usrclk pad to internal_osc.
But there would be error when it's executed.
We check and found there are several process function that can not be able to be recongnized by quartus_sh, such as load_devices, open_sof, write_sof.
Can anyone answer it? Or how to execute it? Is there something wrong?
The following is the script:
proc main_run {} {
global argv
set projName [ lindex $argv 1 ]
load_package asm2
load_devices
set sofName "output_files/$projName.sof";
# set sofName "$projName.sof";
set handle -1
set handle [ open_sof $sofName ]
if { $handle >= 0 } {
set_attribute $handle hssi_aux_0_1 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC
set_attribute $handle hssi_aux_1_1 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC
set_attribute $handle hssi_aux_0_0 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC
set_attribute $handle hssi_aux_1_0 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC
set_attribute $handle hssi_aux_0_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clksel_osc CB_INTOSC
set_attribute $handle hssi_aux_0_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clkdiv_sel DIV4
set_attribute $handle hssi_aux_1_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clksel_osc CB_INTOSC
set_attribute $handle hssi_aux_1_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clkdiv_sel DIV4
write_sof $handle $sofName
} else {
puts stderr "Failed to open sof file $sofName"
main_run
