21612 Discussions
How to target memory mapped by pcie testbench?
hi guys!!:)
I'm try simulate a PCIe communication and I'm setup a testbench.
I just use BAR0 whose size is 4MBytes - 22bit.
The address of that memories slaves are:
Memorie 1 : 0x0000_0000 - 0x001f_ffff
Memorie 2 : 0x0020_0000 - 0x0020_3fff
Memorie 3 : 0x0020_4000 - 0x0020_41ff
memorie 4 : 0x0020_4200 - 0x0020_420f
Well I need to target the fourth memory, but I've cant to get good results.
In the testbench there's a task which target a memory. The next is the code:
target_mem_test(
bar_table, // bar size/address info for endpoint
tgt_bar, // bar to access target memory with
32'h0000, // starting offset from bar
512 // length of memory to test 512
my questions are next::confused:
How I can to target to the fourth memory mapped??
That code can let me to target to fourth memory mapped?
Well, I've setup two parameters and code was like:
target_mem_test(
bar_table, // BAR Size/Address info for Endpoint
tgt_bar, // BAR to access target memory with
24'h204200, // starting offset from bar
16 // length of memory to test 512
I've changed that parameters because the 4th memory begin in 0x0020_42 and the length of that memory is 16.(but it doesn't work):cry:
