Programmable Devices
21594 Discussions
How to transfer data from pc to sdram?
What program can I use to transfer data from my PC to the SDRAM or FLASH memory on the board? I am using DE0.
For example I want to transfer the bit stream encoding an image file onto the SDRAM for later processing.
Please let me know if the question is unclear.
So, someone told me I can use control panel but I would like to know how to do it without the magic control panel.
So, using the de0 control panel, I am trying to write some values (0 in 0, 1 in 1, 2 in 2) into the flash memory and then dump the contents to a hex file. But having some trouble, doesn't seem to be working.
When I open hex file in notepad I get:
000001000200
Any idea how to understand this?
I am reading a source saying "Every line in a hex file always starts from colon". Hex code for ASCII colon is 3A. So... what gives?
Would have been satisfied to see 000000010002 in hex file but alas no.
Ok I think I figured out this part, seems to be in little endian.
