21336 Discussions
How to update s10_ref (20.2) so that it can be compiled using intel quartus pro 20.4
osmanyagci
What modifications should I do on s10_ref (20.2) so that it is compiled successfully in intel quartus pro 20.4? When I try to compile it on intel quartus pro 20.4 without any modifications, it gives the following error. I am new to these concepts including PCIe, so I can not keep going. Can anybody help me on making necessary basic changes so that it is compiled successfully?
Error:
Thanks in advance,
I would appreciate your response
sstrell
In the IP tab of the Project Navigator in Quartus, double-click the IP with issues to reopen its parameter editor.  You should be able to fix the issues there, regenerate the IP, and then recompile the design.
skbeh
1) To upgrade a design to newer version, open the Quartus project, go to Project --> Upgrade IP Components.
Example:
2) Select the IP component that required upgrade --> click 'Upgrade in Editor', the IP component GUI will pop-up --> Generate HDL...
