Programmable Devices
21615 Discussions
How to used Quartus II Tcl Example: Make All Pins Virtual
I had tried the scripts in
altera.com/support/examples/tcl/all_virtual_pins.html?GSA_pos=1&WT.oss_r=1&WT.oss=Quartus%20II%20Tcl%20Example:%20Make%20All%20Pins%20Virtual
For the first script it works fine, however for the other scripts “Manually Exclude Certain Pins, Such as Clocks” it failed.
The problem happens with the line below:
array set opts [::cmdline::getoptions quartus(args) $options]
And the error show:
# source make_all_pins_virtual.tcl
# make_all_pins_virtual -exclude { CLK ARSTn }
can't read "argv": no such variable
I am using the scripts from the tcl consule in quartus II and save the scripts as “make_all_pins_virtual.tcl”
Please give some advice on the error, did I do anything wrong?
Thanks in advance for any help that provided.
Best regards
kelly
I am seing some similar error on that, can anyone help?
thanks
