Verilog
in verilog, how to do like q <= d[count:0]?
reg [3:0] count;
thanks
The expression can't result in a valid syntax, I think. The right-hand-side has a variable length, it can't be assigned to a target with (obviously) fixed length. Furthermore variable ranges are not supported. You should think about an iteration, that copies individual bits.
You might get a registered mux out of that. Really though I would re-write that as a mux if that was your intent since someone picking up your source file might struggle to figure out what it's supposed to do.
Fvm,
i have tried on iteration but all fails. do you any simple example on iteration for my case?
I didn't understand your intention yet. Do you mean to select a single bit? [count:0] is a range rather than a bit. Please clarify also the type of the other involved signals.
My intention is same as to select range of bits. From your previous post, you suggest me to do iteration to achieve my intention. However, i fail to do it using for loop. That's why asking for some example.
O.K., select a range of bits. But you can't assign a variable length selection range to a fixed length target. So again, what's the type of involved signals and what kind of assignment is intended for it.
the count(reg) is dependent on input while q is output. it is non blocking assignment. Does blocking or non blocking play an important role in it?
thanks
--- Quote Start ---
--- Quote End ---
Not in this case, I think. What is the bitwidth of d and q?
Both of it also 32bit.
module test ( input d, input count, output reg q ); integer i; always @(*) begin for (i=0;i<=count;i=i+1) q <= d; end endmodule
thanks. it is very simple and helps me
hello .
am running verilog code and the same error keep showing up ,
errors :
Error (10028): Can't resolve multiple constant drivers for net "hazard" at design1.v(159)
Error (10029): Constant driver at design1.v(138)
Error (10028): Can't resolve multiple constant drivers for net "sample" at design1.v(159)
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 4 errors, 5 warnings
Error: Peak virtual memory: 181 megabytes
Error: Processing ended: Tue Apr 20 13:20:20 2010
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 6 errors, 5 warningshttp://www.alteraforum.com/forum//proweb/misc/progress.gif
this is the code ;
module design1 (
clock ,
reset ,
hazard ,
pulse
); // End of port list
//-------------Input Ports-----------------------------
input clock ;
input reset ;
input pulse ;
//-------------Output Ports----------------------------
output hazard ;
//-------------Input ports Data Type-------------------
// By rule all the input ports should be wires
wire clock ;
wire reset ;
//-------------Output Ports Data Type------------------
// Output port can be a storage element (reg) or a wire
reg [15:0] pulse_cntr;
reg pulse_reset;
reg [15:0] period_cntr;
reg [15:0] sample_value;
reg sample;
reg [23:0] result, result_ns;
reg [23:0] vt;
reg hazard;
initial begin
hazard = 1'b0 ;
end
always @ ( sample_value ) begin
result_ns = sample_value * 4'hc;
case ( result )
24'h00006c: vt = 24'hcccccc;
24'h0186A0: vt = 24'h007530;
24'h030D40: vt = 24'h00EA60;
24'h0493E0: vt = 24'h01ADB0;
24'h061A80: vt = 24'h020F58;
24'h07A120: vt = 24'h029810;
24'h0927C0: vt = 24'h030D20;
24'h0AAE60: vt = 24'h038270;
24'h0C3500: vt = 24'h041EB0;
24'h0DBBA0: vt = 24'h04BAF0;
24'h0F4240: vt = 24'h053020;
24'h10C8E0: vt = 24'h05CC60;
24'h124F80: vt = 24'h064190;
24'h13D620: vt = 24'h0704E0;
24'h155CC0: vt = 24'h077A10;
24'h16E360: vt = 24'h07EF40;
24'h186A00: vt = 24'h086470;
24'h19F0A0: vt = 24'h0927C0;
24'h1B7740: vt = 24'h099CF0;
24'h1CFDE0: vt = 24'h0A6040;
24'h1E8480: vt = 24'h0AFC80;
24'h200B20: vt = 24'h0B4AA0;
24'h2191C0: vt = 24'h0C0DF0;
24'h231860: vt = 24'h0CAA30;
24'h249F00: vt = 24'h0D1F60;
24'h2625A0: vt = 24'h0DE2B0;
24'h27AC40: vt = 24'h0EF7E0;
24'h2932E0: vt = 24'h0EF420;
24'h2AB980: vt = 24'h0F9060;
24'h2C4020: vt = 24'h102CA0;
24'h2DC6C0: vt = 24'h10EFF0;
24'h2F4D60: vt = 24'h116F20;
24'h30D400: vt = 24'h120160;
24'h325AA0: vt = 24'h12C4B0;
24'h33E140: vt = 24'h1360F0;
24'h3567E0: vt = 24'h13D620;
24'h36EE80: vt = 24'h149970;
24'h387520: vt = 24'h1535B0;
24'h39FBC0: vt = 24'h15D1F0;
24'h3B8260: vt = 24'h169540;
24'h3D0900: vt = 24'h1731A0;
24'h3E8F9F: vt = 24'h17A6B0;
24'h401640: vt = 24'h1842F0;
24'h419CE0: vt = 24'h190640;
24'h43237F: vt = 24'h19A280;
24'h44AA20: vt = 24'h1A65D0;
24'h4630C0: vt = 24'h1ADB00;
24'h47B760: vt = 24'h1B7740;
24'h493E00: vt = 24'h1C3A90;
24'h4AC4A0: vt = 24'h1CD6D0;
24'h4C4B40: vt = 24'h1D7310;
24'h4DD1E0: vt = 24'h1E3660;
24'h4F5880: vt = 24'h1ED2A0;
24'h50DF20: vt = 24'h1F95EF;
24'h5265C0: vt = 24'h203230;
24'h53EC60: vt = 24'h20A760;
24'h557300: vt = 24'h2191C0;
24'h56F9A0: vt = 24'h222E00;
24'h588040: vt = 24'h22F150;
24'h5A06E0: vt = 24'h238D90;
24'h5B8D80: vt = 24'h2450E0;
24'h5D1420: vt = 24'h243610;
24'h5E9AC0: vt = 24'h258960;
24'h602160: vt = 24'h264CB0;
24'h61A800: vt = 24'h271000;
24'h632EA0: vt = 24'h27AC40;
24'h64B540: vt = 24'h282170;
24'h663BE0: vt = 24'h290BD0;
24'h67C280: vt = 24'h29CF20;
24'h694920: vt = 24'h2A6B60;
24'h6ACFC0: vt = 24'h2B07A0;
24'h6C5660: vt = 24'h2BCAF0;
24'h6DDD00: vt = 24'h2CB550;
24'h6F63A0: vt = 24'h2D5190;
24'h70EA40: vt = 24'h2F4D60;
24'h7270E0: vt = 24'h2EB120;
24'h73F780: vt = 24'h2F7470;
24'h757E20: vt = 24'h2FE9A0;
24'h7704C0: vt = 24'h30ACF0;
24'h788B60: vt = 24'h317040;
24'h7A1200: vt = 24'h320C80;
default : vt = 24'h0000;
endcase
if ( result_ns <= vt )
hazard = 1;
else
hazard = 0;
end
// Pulse Counter
always @(posedge pulse or posedge reset) begin
if ( reset == 1'b1 ) begin
sample_value <= 0;
pulse_cntr <=0;
hazard = 0 ;
end
else if (sample == 1)
begin
sample_value <= pulse_cntr+1;
pulse_cntr <= 0;
sample <= 0;
end
else
begin
pulse_cntr <= pulse_cntr + 1;
end
end
// Period counter
always @(posedge clock or posedge reset) begin
if (reset == 1'b1)
begin
period_cntr <= 0;
sample <= 0;
hazard = 0 ;
end
else if ( period_cntr == 16'h000f)//557300
begin
period_cntr <= 16'h0000;
sample <= 1;
end
else
begin
period_cntr <= period_cntr + 1;
end
end
if (reset == 1'b1)// begin
result <= 0;
else
result <= result_ns ;
end
endmodule // End of Module design
The error message means that you are not allowed to use your output hazard in more than one always block.There´s the same problem with your reg sample. Try to fix that first, maybe there are some more problems.
Please do not multipost your question
