21594 Discussions
How to view the contents of DualPort Ram memory using SignalTap II?
Can somebody tell me how to check the contents of memory in Dual port RAM by using SignalTap II?
I notice that we cannot use In-System Memory Content Editor to check the contents of memory in DualPort RAM.
Thanks for any quick response...
You have to add logic to read it through one of the existing ports in your design, or catch the data when they are written.
Actually, I have used the Memory Initialization file .mif in my DualPort RAM. I am beginner of using SignalTap II ELA.
Do you mean I have to create one register/output port and assign the output,q ram data to register/output port and use signaltap II to tap this signal?
Can I directly tap the output,q data from RAM?
Thanks for helps.
--- Quote Start ---
--- Quote End ---
Yes, you can.
