21600 Discussions
Clock control block
I need detailed information about clock control block, Can some one help me?
And how to set clock select for a clock control block in programming file(.SOF or .POF).
--- Quote Start ---
--- Quote End ---
for detailed information look into the clock chapter of your device in use or in the documentation of the clock control block in the Megawizard.
You can`t change the selection directly in the pof or sof, this has to be done in your design.
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
I forgot to post the link to the userguide:
http://www.altera.com/literature/ug/ug_altclock.pdf
Kind regards
GPK
