Programmable Devices
공지
21615 토론
I Have imported the correct libraries and still get an error.
명예로운 기여자 II
1,312 조회수
So i have this little piece of a datapath entity.
library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity Datapath is port (
R1, R2, E1, E2, E3, E4, E5: in std_logic;
CLOCK_50: in std_logic;
SEQIN,SQR: in std_logic_vector (9 downto 0);
SW_erro, end_game, end_time, end_round: out std_logic;
Smt: out std_logic_vector(3 downto 0);
SmN: out std_logic_vector (3 downto 0);
result: out std_logic_vector (7 downto 0)
end Datapath;
architecture arqdtp of Datapath is
signal SmSwitches: std_logic_vector(2 downto 0);
signal SeqRom, SeqSw: std_logic_vector(9 downto 0);
signal SmT_in, SmN_in: std_logic_vector(3 downto 0);
signal C: std_logic;
begin
-- Registrador e Somador:
P1: process(CLOCK_50,R1)
begin
if (R1 = '1') then -- R1 Time reset
Smt_in<= "0101";
elsif (CLOCK_50'event AND CLOCK_50 = '1') then
if (E1 = '1') then
Smt_in <= Smt_in - '1';
SmT <= SmT_in;
end if;
end if;
end process;
P2: process(CLOCK_50,R2)
begin
if (R2 = '1') then -- R2 reset Next round
SmN_in<= "0000"; -- Soma Next round
if (E3 = '1') then
SmN_in <= SmN_in + '1';
SmN <= SmN_in;
end if;
end if;
end process;
-- Comparador:
end_time <= '1' when (Smt_in = "0000") else '0';
end_round <= '1' when (SmN_in = "1010") else '0';
end_game <= '1' when (SeqSw = SeqRom)else '0';
SmSwitches <= (SEQIN(1)+SEQIN(2)+SEQIN(3)+SEQIN(4)+SEQIN(5)+SEQIN(6)+SEQIN(7)+SEQIN(8)+SEQIN(9)); -- For some reason it gives me the error here.
SW_erro<= '1' when (SmSwitches > "0100") else '0';
-- Sequencia secreta
P3: process(CLOCK_50,E4)
begin
if (E4 = '1') then -- Sequencia do Jogo reset
SeqSw<= "0000000000"; -- Sequencia 4 bits
elsif (CLOCK_50'event AND CLOCK_50 = '1' and E2 = '1') then
SeqRom <= SEQR;
end if;
end process;
-- Sequencia escolhida
P4: process(E5)
begin
if (E5 = '1') then -- Sequencia Escolhida reset
SeqRom<= "0000000000"; -- Sequencia 10 bits
C <= end_game;
result <= ("16" * C) + ("10" - SmN);
end if;
end process;
end arqdtp;
and i am still getting: Error (10327): VHDL error at Datapath.vhd(53): can't determine definition of operator ""+"" -- found 0 possible definitions
Can anyone please help me? It is urgent.
0 포인트
2 응답
명예로운 기여자 II
449 조회수
Go through the previous thread.
http://www.alteraforum.com/forum/showthread.php?t=1891
1. Adding 9 1-bit data (SEQIN) and displaying the result in a 3-bit (SmSwitches), You required to use VHDL concatenation operator (&) is used to put a 0 in front/back of each of the 9 1-bit numbers before adding them.
SmSwitches <= ("00"& SEQIN(1)+"00"& SEQIN(2)+"00"&SEQIN(3)+"00"&SEQIN(4)+"00"&SEQIN(5)+"00"&SEQIN(6)+"00"&SEQIN(7)+"00"&SEQIN(8)+"00"&SEQIN(9));
2. You can use numeric and unsigned library.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
0 포인트
명예로운 기여자 II
449 조회수
The SmSwitches signal is declared as a 3-bit vector. How are you trying to add or concatenate 9 bits into a 3-bit vector ? If you're trying to concatenate bits to form a 3-bit signal then you need to use the '&' operator.
0 포인트
응답
