I/O Pin voltage
I am trying to design a simple multiplexer using the Cyclone III FPGA on the DE0 board. I am using the PLL to divide the 50MHz on board clock down to the appropriate speed. However whenever I try to put a signal out to one of the I/O pins, it is only about 20mV peak to peak. I understand the pins on the DE0 board should put out 3.3V. I have the pins assigned to the 3.3V standard in the Quartus II pin planner, but it doesn't seem to make any difference. Any help would be appreciated.
You can try the following steps to set the output voltage:
Menu : Assignments -> Device -> Device and Pin Options
In Voltage Tab you can choose 3.3V LVTTL for Default I/O Standard.
Then don't forget compile your project.
I also use DE0 board and every time I use the default voltage.
I hope it can help you.
