Programmable Devices
21611 Discussions
I have problem to get counter to PWM
I'm trying to assign _t3 value from _t1, before I reset _t1 to 0. And I use _t3 value to run next pwm to out
Here is the code.
module convert_Ref(input clk, input in, output reg out);
reg [15: 0] _t1, _t2, _t3, _i1;
reg _tA, _tB;
initial begin
_t1 = 0;
_t2 = 0;
_t3 = 0;
_tA = 0;
_tB = 0;
_i1 = 0;
end
always @(posedge clk) begin
if (in) begin
if (_tA) begin
_t3 <= _t1;
_t1 <= 0;
_t2 <= 0;
_tB <= 1;
end
_tA <= 0;
_t1 <= _t1 + 1;
end
else begin
if (!_tA) begin
_tB <= 0;
end
_tA <= 1;
_t2 <= _t2 + 1;
end
if (_tB) begin
_i1 <= _i1 + 1;
if (_i1 < _t3)
out <= 1;
else
out <= 0;
if (_i1 == (_t3 + 100))
_i1 <= 0;
end
end
Rule number 1 of coding: Make it readable :). Please use meaningful signal names. '_t1' doesn't tell me anything.
A tip when posting code: wrap the code tags around any text you post. e.g.
module convert_Ref(input clk, input in, output reg out); reg _t1, _t2, _t3, _i1; reg _tA, _tB;
Then you won't end up with unwanted smilies B) littered about your code and it will maintain any (very helpful) indentation you may have included in your original code...
As for the actual problem with the code - I'm really not sure what you're trying to achieve. You mention PWM in the title but I really can't see what you're trying to do.
For starters: counter '_t2' increments under certain conditions but nothing is dependent on it. So, what is it there for?
Perhaps a description of what it is you're trying to do would be the place to start...
Alex
