21615 Discussions
I instantiaze a pll with 4 output clock,but when I use Derive PLL Clocks command in Timing Analyzer, it only derive two generated clock?
zlan01
altpll1 altpll1_inst (
   .inclk0 ( chip_clk ),//20Mhz
   .c0 ( sys_clk ), //400Mhz
   .c1 ( uart_clk ), //25Mhz
   .c2 ( clk_50M ), //50Mhz
   .c3 ( clk_30M ),//30Mhz
   .locked ( locked_sig )
according the route " Timing Analyzer->constraints->Create Generated clock "
to open "Create Generated Clock" window ,
and the open the ->source window
there are just the output clock clk[2] and clk[3] of the pll,where is the clk[0] and clk[1] of the pll?
by the way the ouput clk[0] is 400Mhz, and the ouput clk[1] is 25Mhz ,
and after run the create generate clock command ,there are only
the generate clock clk[2] ,cllk[3], what is the reason ?
Rahul_S_Intel1
Hi ,
When I made a simple PLL and try to put the list fro the name finder , I can see all the out put from the PLL . May I know is that is a problem for you . The same is not view by you
Rahul S
zlan01
oh, perhaps because I only do synthesis step, and do not do the fitter step
sstrell
And you don't even need to create the generated clocks like this. Just put derive_pll_clocks -create_base_clocks in your .sdc file to automatically create all the clock constraints from the PLL IP.
#iwork4intel
