21615 Discussions
I/o constraints in stratix v fpga using quartus 13.0
Hi!
In my design , a quad-channel adc 9253 is sending input to Startix 5 FPGA. In FPGA ALTDDIO_IN is used to process incoming data @ Double rate . While testing ADC alone with test patterns , I found 2nd channel of ADC output ,that is ALTDDIO_IN output is either misaligned with the frame clock of ADC or wrong patterns .
adc data clock = 440 mhz
adc frame clock =110 mhz
channels = 4 (lvds pairs)
input to 1 altddio_in = 2 (from channel 1) likewise , i have 4 altddio_in ...
To combat this , I have added IO constraints like this for the channel 2 .
set_input_delay -add_delay -clock [get_clocks {clk_adc}] -0.5 [get_ports {i_adc_chip1_data[2]}]
set_input_delay -add_delay -clock [get_clocks {clk_adc}] -0.5 [get_ports {i_adc_chip1_data[2](n)}]
i found a doc from altera , that while io constraints ,virtual clocks should also be used to add input or output delay .
Is the above delay setting is sufficient or wrong ????
regards
JAYV
